Need Help: Silverstar Fog Light Install
Tleahcim
I just purchased the Silverstars and replacing the fog light bulbs seems to be a bit of a mystery to me. I'm assuming that I'll need to get under the vehicle and do some unscrewing in order to access the bulbs, but didn't know if someone had a better way or a proper order that I should go about do thing this.
Thanks in advance.
No need to unscrew anything....
What I did to replace my fog lights....
1) open the hood
2) before the radiator there should be enough room for you to reach the fog lights. (flaps are moveable)
3) reach all the way down, turn, pull, and replace.
4) reverse the steps. do to other side.
what iForce said works...i did mine from underneath, i had no problems reaching up and turning the light bulbs to remove them
I tried squatting and the doing it.. my hand started to cramp up. THat's why I did it from the top instead. Maybe next time i'll actually roll under there. :D
I changed mine from underneath with no issues. Just make sure you are placing the bulb straight in (no tilt), otherwise turning it gets frustrating.
yeah, i also replaced from the bottom....quite easily....it just hapened to be like 10 degrees outside, but other than that, no problems!
