Need Help with a Frame Attachment Broken/Missing Piece, maybe?...(AKA What the hell?)
navygse1
Greetings fellow 3rd Gen owners...I am in need of your assistance!
The attached pics are of my '02 Limited 4x4, I was finishing up putting on poly bushings on the front sway bar when I noticed the broken tabs connected to the frame.
My first thought is they might be for a shield (rock, splash, etc.), but upon looking closely it is made of some sort of a fiber material...plastic, fiberglass...
My T4R has the steel rock guards under the radiator, xfer case, and gas tank.
As Iam not the original owner, I assume a previous caregiver broke this off. (The radiator shield bolts are stripped and all different sizes, so I bet this is a casualty of Edwards HEAVY Hands!
With no clue as to what I should look for to replace it...I figured I would reach out to the community!
Any assistance is greatly appreciated!
Thanx in advance...
Mike
Thanx!
For $138, I will remove the broken tabs and call it a day!
Appreciate the assist...the biggest reason I try to stay away from used cars...but for a 3rd Gen, no other choice!
Again, thanx for the lightning quick response!
Not sure why the pics inserted upside down...so apologies for that!
My 97 didn't have one either, but I installed one. It covers the fuel filter and fuel tubes. It breaks easily when you put it on a lift.
Mike Sargent
