T4Rscott
Hi all,
As some of you may know, I have been battling off and on, an AC that won’t engage the clutch at idle.
I have done/ replaced the following:
Condenser
Receiver/ dryer
Pressure switch
Evaporator
Thermistor
Changed TPS
Changed IAC
Swapped compressor/tested clutch
Swapped ECM
Swapped amplifier
Continuity/voltage on harness.
Checked and swapped AC switch
So I believe there’s a wire not getting signal. I need someone to explain what wire signals the idle, and what should I see for voltages.
I know I’m getting close. I will be going through the grounds and checking the fan clutch.
Condenser
Receiver/ dryer
Pressure switch
Evaporator
Thermistor
Changed TPS
Changed IAC
Swapped ECM
Swapped amplifier
