Need help with factory radio
01svtL
This weekend, I put a cd in the stock, non-JBL radio. It accepted it, but then wouldn't play. It jumped over to the AUX input and won't go back to CD, so it won't play the CD. It also will not eject the CD. Is there some kind of reset or anything here?
I don't believe there is a manual eject funtion, like using a paper clip, that you can use. It sounds like either the CD function jammed or the CD jammed it up.
Either way, you should be able to pull the unit and take the top off and get at the cd that way.
I have an 06 non JBL for sale if you are interested.
I agree that it sounds like you have a jammed CD.
Take the unit out nd remove the outer-housing cover.
I replaced my 03's stock non-JBL with a Scion T1808 w/ IPOD control cable. I recommend that simple mod to ANYONE who doesnt have it.
I second that Zero! :iagree::D
There are threads in here showing which panels and screws, etc. you have to remove, but in general: You remove the front panel surrounding the unit and you unscrew and slip it out..
You cannot use, as far as I know, a JBL in a vehicle that came with a NON JBL without some modding. The JBL system has more speaks and has a in vehicle SUB that the non did not. That radio needs those to work I believe.
That said. You can use any aftermarket you want. Those of us that have the JBL system cannot just throw a aftermarket in and use all our speakers. We have to purchase an adaptor.
So. If your cd unit is fried and you don't have the JBL system, then I would look for a nice aftermarket head unit by pioneer or kenwood.
Well i am running an aftermarket amp and speakers already anyway. Having said that, would te JBL unit work? I want to keep a factory look.
Wow. Try to give ALL the info first post. :) Your story kept changing with every post.
As for running the a JBL head unit with non-jbl speakers and sub, that is a really good question. I honestly have no idea.
Take a look at this:
Issues getting factory JBL amp to work with aftermarket stereo - PriusChat Forums
JBL is such a good setup in part because they take into account almost every variable. As such, their systems are calibrated to specific headunits, speakers and amps.
While I have no doubt you could physically wire up the unit manually, I have no idea how the JBL headunit will run the non jbl speakers and sub. Make sense.
You may just have to try and see, and not be too pissed if it doesn't work well.
In your case, I suggest a NON jbl headunit as it will likley play nicer.
Haha I only made 2 posts with a "story."
I'm thinking if an aftermarket amp is already connected to the back of my current radio, it should be just plug and play with the JBL radio. More input would be appreciated from anyone with similar setups.
Actually, what I was trying to say, is you with every post you kept amending or changing the facts, which altered the answer.
My point was, full disclosure upfront saves time. At first it was, CD STUCK. Then it was, will a JBL work? Then it was, I have aftermarket equipment already installed.
Each one of those are different things and give different responses.
So. Yes. You told a convoluted "story" with new variables being introduced.
As for the JBL with the AMP, yea; wire it up. I am sure it will "work", how well depends. Like I said earlier, JBL headunits are designed and tested around specific conditions.
I dont really see how i changed the story. The cd IS stuck. Sooo, if the radio is screwed, will the JBL work as a replacement?
Someone THEN said not without the other JBL components, at which point I added that i had aftermarket components anyway. Having aftermarket components has absolutely nothing to do with an answer to my original post, and this fact would still be completely useless to this discussion had I not asked about the JBL unit. I would not have brought up the JBL unit had someone else suggested that mine might be fried and to look for a new one, which IS an answer to my original post. I really dont see where there could possibly be any confusion here.
QUOTE=DC runner;864772]You cannot use, as far as I know, a JBL in a vehicle that came with a NON JBL without some modding. The JBL system has more speaks and has a in vehicle SUB that the non did not. That radio needs those to work I believe.
So. If your cd unit is fried and you don't have the JBL system, then I would look for a nice aftermarket head unit by pioneer or kenwood.[/QUOTE]
Can you get to the cd's the same way with the JBL 6 cd. My cd player wont work and dealership said $200 to fix. No thanks
Jim, here is a thread that I posted recently. The link in the first box has the step by step procedure with pictures on how to remove the unit. Just print it out and take it outside with you and follow the instructions.
http://www.toyota-4runner.org/4th-gen-t4rs/96324-new-scion-t1808-installed.html
These instructions are for taking out the navigation system which I don't have. I was just wanting to replace the stereo system head unit and I do have the JBL system. Really I just want a jack to play the MP3 player.
Dude, did you look at those steps? The NAV systems and the non JBL and the JBL radio all go in the same location in the 4runner. It's the same way to get to the radio for all 4th gens.
