Need Help With Jbl Amp.
firstyota
I HAVE THE 2007 SOLARA NAV AND I AM INSTALLING IT INTO A 2004 4RUNNER WITH THE JBL SYSTEM. I ORDERED THE MIC, RIBBON, AND RIGHT SIDE BUTTONS TODAY. THE DEALERSHIP COULD NOT FIND THE MODEL NUMBER FOR THE NEW AMP. DOES ANYONE KNOW THE MODEL NUMBER FOR THIS. ALSO WILL THE NEW AMP JUST PLUG AND PLAY (DO NOT NEED TO RUN EXTRA WIRES).
ALSO DOES ANYONE KNOW THE PART NUMBER FOR THE GPS ANTENNA.
THANKS FOR ANY HELP.
Do you need the number of the amp in the 4runner. If so it's 86280-OW150. To answer the plug and play question, if the Solara HU was JBL then the amp should just plug in. However you will need some wires for the nav functions.
Thanks for the info. do you know if that is the new part number for the amp. do you know what wires I have to run. Thanks again for the part number.
There are full schematics for the 4th gen runners. Try a search in audio and electronics. As far as I know all 4th gens come with the same JBL amp.
I looked at the diagram at the dealership today and we could not find it. I will try the part number you have given. In 2006 they switched to a new amp and that is the one I need to run wires for the nav unit to work. Thanks again for the info.
