Need help with PS o-ring
T4Rscott
Hey all,
I removed my power steering reservoir to clean out the garbage inside.
When I went to reattach it to the pump, the 20 year old o-ring broke. Does anyone know the size or number (not the part#) this o-ring is? Is this nitrile rubber?
This little o-ring is keeping me from getting this done, and none of the dealers have it in stock.
Thanks,
Scott
Hey all,
Thanks,
Scott
In stock here: Elbow O-Ring - Toyota (90301-11016) | Toyota Parts
Best to just take the res. with you and match one up. An assortment kit should have something to make do.
I guess that's why the FSM calls that part non-reusable.
You may want to look up a local Bearing supplier call them and see if they have a Large O ring assortment. They are a good resource for seals and bearings unless you just have to have Steeler-ship.
Where I live there is a place that has whole sale Nuts and Bolts they also do custom oil pressure hose. When getting O-rings in places like hardware stores make sure they are rated for oils.
:brick:
Excellent info
Glad I searched the forums. Exactly what I needed. Will look locally for these shops. Thanks.
Having spent almost a whole day trying to figure out what size spec of o-rings they used in Japan, it's not a kind you'll easily find at American stores, the cross-section sizes are different. Just go to the dealership and see what they have they probably have an assortment of Japanese spec ones.
bobdjr41
