Looking for something high to jump off.
Ok, well things did not go as planned.
Here's an update with the stats more clearly laid out.
Stats: 1998 4runner 155k miles Originally sold out of state
3.4 w/AT, SC, URD 7th and 2.2 Pulley, headers, one cat a magnaflow and magnaflow muffler.
First 02 is a Bosch wide band thread in sensor, post cat 02 sensor is the denso with traditional 2 bolt flange.
Also of important note I have not had any CELs during this time.
Took it for a smog test. Needed a new gas cap. Passed all but one category on 15 mph test NO was higher than limit. 25 mph test was fine. (see numbers below)
Started replacing items: New plug wires, new Ik22 plugs (those were the recommended plugs and what was already in it), new PCV valve, new gas cap, new upstream O2 sensor (same one in it as above), cleaned the MAF and throttle body, changed oil/filter, ran some of that CRC guaranteed to pass snake oil through it, then filled it up with some Chevron premium got it good and warmed up took it back to smog place and ….. any guesses…? Well it was 2-3 times worse across all levels (see second numbers)
---------%CO----------%O2-------------HC (ppm)-------------CO%------------NO (ppm)----------Results
Test----meas----------meas------------max/meas---------max/meas----------max/meas
15mph--14.7-----------0.0--------------51 / 20----------.65 / .28---------512 /847--------------fail
25mph--14.8----------- 0.0--------------35/15------------.79 / .24---------765 / 697-------------pass
Test 2
15mph--13.9------------0.6--------------51 /104------------.65/ .65---------512 / 2056--------gross polluter
25mph--14.3------------0.3--------------35 / 62------------ .79/ .50---------765 /1497-------------fail
After I got done saying $%$#^**^^$##@%^&((())_&&&, and where is my Glock G17? I took a couple days off of dealing with it.
So, I’m out of state for a few days and trying to come up with my next plan.
Could a cat, crap the bed in two weeks, not throw a CEL and still cause this? The numbers have jumped 2-3 times in value. I’m at a total loss. The smog tech said the numbers look like the car doesn’t have a cat. The cat, was a 49 state cat, and if I need to replace that now, my guess is they will have to install a CARB (hate them) approved unit.
Any ideas? Thanks for your help/ideas. No I wouldn’t shoot my 4runner, I really do love it.
:gun4:josh
