I'm replacing my factory shocks after 153k miles on my 99 T4R 2WD. I'm thinking of getting monroe sensa-trac because of the, buy 3 and the 4th free, deal. Then again, I keep on reading that Bilstein are better. I never go off roading or tow. Looking for a smooth ride. Also, the rear sags. I want to fix that while I replace thee shocks. I read that one person switched into new shocks and still had the sag. What can I do to fix it? I'm new at this so what is the difference between springs and coils? Someone mentioned to buy the 99 tall springs. But what about coils? Hope someone can help. Thanks.
I want to post a thread of my suspension work with pics later, but to answer your question from a personal experience...
I have a 1999 SR5 4wd 4Runner with the p265 70 R16 tires and I just replaced my struts (front of vehicle with COILOVER springs) and shocks plus new SPRINGS in the rear. Also replaced swaybar bushings and end link bushings front and back. Did all the work last night 4/28/2011 (all night LOL!) OK here goes...you asked for it...
I bought this Runner used in 2009 10 years old it already had 236k miles but it did not bother me cause I have friends that swear by Toyota especially Runners...well needless to say I was disappointed with the ride right off the bat but since we got a good deal on it I just promised myself to upgrade the ride...well to my utter disappointment and LACK OF EXPERIENCE and SCHOOL OF HARD KNOCKS I went out and bought the best shocks available at
sigh...Autozone they sold me Gabriel Ultra's front and back...thought about the Monroe's but decided against it since they swore by the Gabe's...bad idea they wore out in less than 6 months...and i mean wore out...not started to ride bad...that happened after about 3 months (i did light offroading occasionally maybe like a total of 4 times in the 6 months.) the middles of the strut bottom where the bolt goes through were completely torn up and the backs hit hard all the time. I kicked myself in the grass and swore to never buy cheapies again!
Light at the end of the tunnel...
Finally saved and bought up supplies from
2011 Toyota Parts Zone - Toyota Parts, Toyota Accessories
and also
Summit Racing
I decided to go OEM (original parts) since they were exact matches on all the bushings and washers as well as the 99' rear springs and the rear shocks which I found out are brand name TOKICKO which are put on all Toyota 4Runners i believe. From Summit I bought the Bilstein 24-187244 - Bilstein Heavy-Duty Series Struts, pluse Brake Roters and Brake Pads.
I installed the front struts first (tip I did not make it to my mechanic but would recommend taking the entire strut assembly with your new struts and have them take the coils of the old and put on the new...he would have charged me 15 bucks a piece! instead due to time constraints i rented the strut spring compressor tool from Autozone for 50 bucks which they refund when you bring it back. I ended up needing it though to compress the springs in the back anyway so keep that in mind) once i got the struts installed I immediately took it for a spin with my neighbor who came by to help...holy crap what a difference! On top of that the Bilstein's raised the front like 2.5 inches alone! Very impressed! That was 11:30 pm.
Next I installed the rest of the stuff and finished umm....at 5:30 am! Do not underestimate the rear springs/coils holy crap that was a heck of a job! Also I have a major complaint with Toyota regarding the rear driver side shock top nut and washer! What the !#@*%^? were they thinking you have to be some kind of contortionist to get your freaking hand up there much less get a socket and a ratchet on it...there is all kinds of stuff in the way...contrastingly it took me all of 10 min to swap out the rear passenger side shock and an estimated 1.5 hrs to get the driver side rear! Ok i feel better for saying that! Swaybar stuff was mostly easy day except for the passenger side swaybar bushing bracket removal...holy crap i say again! they position of the nuts and washers on the top of the bracket right under the floorboard and all kinds of crap in the way! Really Toyota that junk was hard as well, make sure and spray repeatedly with WD40 or equivalent for like a week in advance if yours is as old as mine...the end links were a little problematic, i found it easier to undue the swaybar brackets and the end links where they connect to the body and break the nuts for the end links on a workbench where i could muscle it! I did this after breaking my 14mm wrench due to cranking the heck out of it with a bigger wrench on the end of it to get more torque!!!
What's the short answer (Sorry to give it to you last) Do not get anything less than OEM which i think stands for Original Engineered Manufacturer parts or Bilstien or above...Icon...whatever PERIOD!
Sorry for the long answer but did i answer your question? LOL
