need more power
924runnerSR5
i have a stock 92 sr5 5speed v6 with 189000 on her. shes stock but i have a flowmaster and 33 bfg mud terrains. i need more power. any suggestions on what i can do engine wise to get more power? maby turbo her?? or get a 22re and turbo that?
help is appriceated
ty much
There's not much you can do to the 3.0 v6 to make it great. In stock form it lacks, and unfortunately even the common aftermarket parts don't do a whole lot to wake it up. You can attempt to turbocharge the motor, but be prepared to replace head gaskets regularly.
I'm not sure what gear ratio you have, but I recommend 4.88 gears for a 3.0L/5spd with 33" tires. The rolling resistance of a mud terrain, combined with the larger circumference and additional weight of the tire are just too much for the 3.0L to happily handle with stock gearing.
As for possible motor swaps, I would urge you to go big, or go home on such a thing. If you are prepared to undertake a motor conversion, why not convert to something newer and more powerful such as the DOHC 3.4L V6 from the Tacoma and Gen 3 4Runner. The wiring will be the hardest part, as the 3.4L runs OBDII (on board diagnostics 2nd generation), but it is still very do-able.
if I were as rich as I once was, I would put in a toyota/lexus v8.
If I were as a rich as I am not now, I would probably just drop in a ford 302..... I would hate to power a toyota with a damn ford motor, but, you want power? there is a handfuls worth.
its in the back of mind,always
I agree a 5.0L Ford motor would be a great way for more power on the cheap, and if I didn't live in smog crazed CA I would probably consider performing such a swap myself.
The 4.0L DOHC 1UZ-FE Toyota/Lexus V8 is another solid choice.
thanks guys. imma try to keep the truck all toyota. i HATE fords lol. thanks for your help. what is the engine type in the 3rd gens?
i have had both an 88 V6 and 94 V6 both 5-speeds. i put the k&n fipk on the 94 and got a decent power boost (major noise boost) and increased gas mileage...i don't have any numbers though, it's been a while. i later added a set of downey ceramic coated headers to the 94. it's a pain of an install, but getting rid of the rear crossover really opened it up. i, stupidly, left the stock cat and exhaust back stock. changing that out should help some.
