need pic of panhard bar
Just want to be sure what exactly it is that i may need to loosen or remove on rear daystar install.
Not sure why you need to loosen the panhard bar. I've done spacers in the rear of my 4runner as well as 2" springs on a 5th gen and the Panhard bar did not need to be loosened or removed.
You will need to disconnect the sway bar though. I found disconnecting at the endlink is the easiest.
This long bar that runs parallel with the axle. No you don't have to disconnect it.
P1020093.jpg~original
I took it off it's just one bolt from the axle and made dropping the axle way easier...just that bolt and the sway bar endlinks and you're good.
