need rocker switch
DED&DED
Hi everyone,
It has been a while but I just got an ARB bumper installed on my Gen3.
The fog lights harness is factory and that should be no problem.
I am adding running fights also and am looking for OEM rocker switches that match the existing Clutch Bypass switch. A similar switch was used for the e-locker. The local dealer says they are not even in the parts book any longer. My gen3 has 3 blanks on the lower left side of the dash--where the clutch bypass switch is located.
I would prefer to buy the OEM part (new or used) or a very similar after market. Most of the light kit switches are rink-dink.
I appreciate any help along with opinions of LED driving lights both on- and off-road.
Check out the Scion TC switch. Part# 84160-52030
I just happened to see it on another thread this morning. Did you try searching at all?
krenaud33----I have searched but not on this forum. The main thing i learned is that the lighting technology has changed a lot. The higher end lights include the harness and switch--but only a few of the switches are well made and none of them match the space I have available to mount them. I am continuing to look but I still hope someone has already solved this problem.
Thanks for your reply--at least I know someone is out there with enough interest to reply.
