CoMarc
So, I'm installing my suspension lift today and got the coil-overs in place, but found on one side that the sway-bar link rod had been broken (how long, I have no idea). So, I went down to the nearby auto parts place and picked up a couple new ones to replace the swaybar link pieces on each side. I got the broken one off fine, but I'm having problems getting the good side off.
The problem bolt is down at the 90 degree angle.. You have the nut on the opposite side and if you turn that, it just turns the whole piece. There's a flat part on the opposite side that I can't seem to get a good enough grip on to remove the nut. I'm sure that sounded awfully confusig, but for anyone that has replaced their swaybar links you probably know what I'm talking about.
Anyways, I need help figuring out how to get this freakin' thing off! Any suggestions would be most helpful!
Thanks in advance...
