Need some Turbo Help!
lostprophet
So I have a 93 4runner with a 2lt engine swapped into it. I purchased it used, and a couple of months ago my turbo became cracked and is now leaking boost and oil. I need to solve this problem.
Now I know that the turbo that is in there currently is the ct20.
I'm looking to replace this. I have heard that the ct26 should work, wanted to know if anyone can confirm whether or not it bolts up or requires modification.
As well if you know any other turbos that would bolt up with little to no modification that I could use instead I would like to have as many options open to me, so I can find the most cost effective solution.
Quinn
