Need Urgent advice on (Bumper) Tow Capacity.
HialeahScience
Hi Guys.. I have a 2009 4Runner Sport 4WD. It has a "bumper mounted", tow hitch. it's on the steel part of the bumper attached with two bolts . I recently rented a U-Haul 5 x 8 trailer (900lbs) max load (1800lbs). I need to haul some drums, two amps, 2 guitars to a show in Tampa. I can't seem to find what the tow capacity of the bumper is? Am I pushing it? Should I just upgrade to a cargo van? I'm leaving later today and would like some advice,so that I may change the reservation if needed.
Thanks.
It sounds like you have the normal hitch, so the capacity is 5000 lbs, and it doesn't support a weight distributing system. The tongue weight should be up to about 500 lbs. Check your owner's manual or the door frame to be sure.
you should be easily within the towing limits, not sure what the braking setup is on u-hauls though, [MENTION=86678]ebg18t[/MENTION] knows more about that than I, I'm fairly certain they don't utilize electric brakes via an in cab TBC
Uhaul trailers use hydraulic surge brakes. From what I hear it's not as nice as an electronic setup, but it's better than no brakes! I don't think any of them are set up for a weight distributing hitch, so you don't need to worry about that.
If you've never towed before, take it easy and leave tons of room. It will take longer to accelerate and stop, and your rig will be a lot less maneuverable with a trailer behind you. Moves like lane changes and turns may take a bit more planning than usual because you are driving a much longer vehicle, and because the trailer takes a slightly tighter circle in turns, so it's likely to run over stuff like curbs with the inside wheels. Also, avoid backing up and parallel parking with the trailer if you can. If you must back up, read up on it first. It's a bit different than backing up a single vehicle. If you must parallel park, good luck! The one time I had to, I didn't have a lot of room to work with. It took me like 10 minutes with a big 6x12(?) trailer to get the trailer and vehicle close enough to the curb and not angled in a way that they were stuck.
U-Haul use surge brakes as previously mentioned. You will probably need a 7pin plug adapter. Make sure you pack the trailer smart to control the tongue weight. I.E. Keep the weight balanced around the axle. The v6 is fine to haul 5k pounds with out issue.
