need URGENT help before work!
bak3rme
Senior Member
ok so i just got done cleaning the IAC valve. I removed the TB and took the IAC apart to spray down and scrub. (i've taken apart TB plenty of times) i made sure all my wires and such were attached before i start my truck. But now it doesnt start!
it cranks over holds for about 1 second and dies
its different from when i spray TB cleaner down the TB and start up again..i know if i do that it makes a different noise..but this one it seems like it just starts up and shuts off in 1 second!
i need some help quick before work! thanks!
Do you have access to a scan guage?
Sounds like a pissed off sensor to me... but...
any chance there is a gasket problem?
thanks!
BUT
i figured out the problem...on the spark plug thingy...one of the teeth was bent out and didnt connect with the adapter...all good now!
