New 2000 4Runner, laundry list of concerns. Help?!
UrsaAmericanus
Hello everyone, new 4runner owner here.
Just bought a 2000 Toyota 4Runner, 2WD, Base. 50k miles on the odometer. This is a Toyota Certified Used Vehicle, and just brought it home. Test drive was fine, but we all know that the problems come up after you take it home and give it the full rounds...
So, a million minor concerns are coming up, and wanted to make sure if I should either A) Pipe down because I'm being paranoid or am unfamiliar with this vehicle. Or B) Go b**** to the dealer. So here goes (have patience, please):
A) When I am stopped at a light, i sometimes hear an audible "click". Not very loud, but it is audible when the window is rolled down. Only happens every once in a while, so I don't know what that could be.
B) There is a squeak in the front, (I'm guessing something needs to be greased?)
C) The tranny fluid, to my dismay, is slightly brown. Light brown, a bit dirty. Though it still smells like fresh tranny fluid (no burnt smell or anything).
D) When moving from P to "D", the tranny shifts quickly into gear, but is a "bit" noisy. No slippage so far as I'm driving.
E) When driving in tunnels or enclosed areas, and I'm giving it the full gas, it goes just fine. But it seems to run a bit noisy, in that it "rattles" or sounds a bit louder than my little camry. Normal? No?
Any help on any of these issues would be greatly appreciated. The warranty on powertrain and such lasts until 7/2006, so I'd like to get these nailed down. Thanks!
congrats on the new runner:)
A. that "click" your hearing is probably normal. think its the abs system. is it like slight hiss then a pop? you might hear it when you first start it up too. if that's it i wouldn't worry. my '02 has done it since day one. and the other 02 i had before did it too
B. I'd go back to the dealer and point that out to them
C. ditto
D. might be related to c
E. doesnt sound normal to me. but slight pinging could be normal. maybe try running higher octane gas to see if it goes away.
just a thought.
I agree with 02sport, A is normal. I was told the ABS brakes self calibrate after the first stop and may make a slight clicking sound. B through E are not normal and I would have them checked.
Other normal things are:
1.)When I start the engine, it makes a loud roaring sound and then calms down in a few minutes, what is happening is the fan is working and when it warms up the clucth on the fan starts working, theyby making less noise.
2.)The shifter moves slightly when I drive. Coming from a front wheel drive car this action is diffently weird, but I have been told, it is normal.
