new 4runner owener
capt575
hi names don im looking into getting a 1999 4 runner any thing i should be looking at when i go look at them any known issues or it has 143,000 miles on, thanks
Really, "owener"? I know grammar on forums usually isn't the best, but at least use spell check.
Look for all things you would on most cars. Have they done all 30k mile check-ups with records. Oil changes, and no signs of wrecks. Does it run well? Make sure all the motors work, windows, etc. Check all the lights, has it been cleaned? I mean there really isn't anything necessary with late 90's toyota trucks over the norm, if well maintained they will last forever. Just make sure its been well maintained.
look for all things you would on most cars have they done all 30k mile check-ups with records oil changes and no signs of wrecks does it run well make sure all the motors work windows etc check all the lights has it been cleaned i mean there really isnt anything necessary with late 90s toyota trucks over the norm if well maintained they will last forever just make sure its been well maintained.
Translated for the OP.
Really, "owener"? I know grammer on forums usually isn't the best, but at least use spell check.
BTW... It's "grammar". Remember that spell check thing? :hello:
Some of the things I looked for in addition to maintenance records/history, I looked for leaks, body damage, transmission fluid, oil, all electronics, rear seals, rust, undercarriage, driveability. Basically just give everything a good look/feel. Oh and I also looked/asked for recent radiator replacements. Use the above buyer guide and good common sense and you should be fine.
lol sorry about the spelling issue it was a long day. I'll double check everything next time. thanks for the advice on what to check for, I plan on doing a tune up. including the water pump and pulleys, belts. first thing I'm wanting to do is get tires rims and shocks,coils something a little bit more beefy for playing in the trails. I have about 3 grand just to throw at it right now. any suggestions on tire size, lift, rims, btw it already has the stock 16 inch rims with bf goodwrench.
Pics are a must! And I would also suggest going through the gallery and the build thread stickies at the top of the page. Look at some of the rigs that you like to get an idea of what you want in the end. Let us know which ones you do like and we can help you from there!
thanks will do. I just got done reading the sticky that BigFishAllDay posted thanks. a lot of info in there. at least 4 to 6 hundred will be going to maintenance right away just to make sure everything is running in tip top shape, I really don't want to upgrade on bad parts then have something fail lol.
Int's it werid taht you can sitll raed tihs eevn toguhh it's all mxeid up? Eevn wtih bad spleilng or grmamar or wahvteer?
lol wvee all seen it bfroee...
"Cna yuo raed tihs? if yuo cna raed tihs, yuo hvae a sgtrane mnid, too.
I cdnuolt blveiee taht I cluod aulatcly uesdnatnrd waht I was rdanieg. The phaonmneal pweor of the hmuan mnid, aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it dseno't mtaetr in waht oerdr the ltteres in a wrod are, the olny iproamtnt tihng is taht the frsit and lsat ltteer be in the rghit pclae.
The rset can be a taotl mses and you can sitll raed it whotuit a pboerlm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
Azanmig hhu? Yaeh, and I awlyas tghuhot slpeling was ipmorantt!
Qoestuin -
Can thsi be doen in ohter lnagugues? Snapsih, Fenrch, Iatilan, Gerek, Rissuan. Chenise, Jaapense, Herbew, Aaribc? "
