New 4runner...
Uneek said:
IIRC, Thai has a post in one of the sub forums.
AWD: no low range gearing, has a center differential which allows all the wheels to receive power and turn at different speeds. Unibody Toyota SUVs are AWD.
4WD: it has low range gearing, all Toyota trucks and (truck based) SUVs that are 4x4 are 4WD, some are part-time while others are full-time.
Full-time 4WD: has low range gearing and a center differential, which allows it be driven with power to all the wheels to receive power and turn at different speeds. Locking the center differential in makes it behave like a part-time 4WD vehicle because all four wheels rotate at the same speed.
Part-time 4WD: has low range gearing and no center differential, all four wheels recieve power, but cannot turn at different speeds. Thus part-time 4WD drive systems should not be operated on dry pavement, since it'll cause excessive and unneccessary wear on the driveline and/or tires.
TORSEN: stands for TORque SENsing. Both V6 and V8 4WD 4Runners have this. TORSEN center differential is what allows the 4Runner to split it's power upto 71% to the rear and 53% to the front under slippage conditions with a normal 40/60 front/rear split under normal conditions.
With that said, the 4th gen V6 4WD 4Runner in 4H is no different than the V8 4WD. I stick by my statement that the 4th gen V6 4WD 4Runner is a full-time 4WD with the option of 2WD.
At least you put it into three categories like I was trying to get at PT/FT/Torsen.
I agree with all that, and everyone else for that matter. I guess I was getting hung up on the system being something altogether different than the norm for 4wd systems (PT/FT) because of the 2wd option in the V6. I guess I was just reading/thinking too much into it. Anyway it was enlightening, thanks.
I have the 06 V8 4x4 Sport. I did originally go with the V8 mostly for towing benefits, but now that I have it I'm glad I did for it's benefits on road and off. Extra HP always comes in handy if not abused... especially off road.
I tell you this to comment on power benefits versus mileage. To be honest, I wish I had better mileage (I average 15.5 mpg) but I wouldn't give up the power. If you can afford the V8 and the extra trips to the pump, you won't be disappointed in your choice.
Of course we all have our own priorities.
AndiGarage
