New BMW M5 with V10
Thai
Elite Member
M stands for Monster: New M5 promises to be BMW's hottest production sedan ever
By GREG KABLE
2006 BMW M5
ON SALE: 2005
BASE PRICE: $80,000 (est.)
POWERTRAIN: 5.0-liter, 500-hp, 369-lb-ft V10; rwd, seven-speed manual
CURB WEIGHT: 3900 pounds (est.)
0 to 60 MPH: 4.7 seconds (est.)
Replacing a landmark car is never easy. When the landmark car has whipped every conceivable rival in convincing fashion in its lifetime, the job is even harder. And that's the task the new BMW M5 faces. Its iconic predecessor set the sport sedan standard for six years, until it ceased production late last year.
Rather than rest on its laurels and simply refine a winning package, BMW's M division has dug deep into its development coffers to raise the four-door stakes-again.
The concept behind the new M5 is the same as always: "To blend an unobtrusive appearance with a high-performance engine and premium levels of sedan car comfort." But this execution is different, more courageous than any in the model's 20-year history.
Everything you need to know about Munich's new 155-mph four-door flyer is summed up in the sophistication of the monster engine behind the signature kidney grille. This F1-inspired V10 signals the M division's newfound determination to not only demolish its rivals on driving finesse, but to do so with outright grunt as well.
By replacing the previous model's 4.9-liter V8 with a 5.0-liter V10, BMW elevates the performance potential to a higher plane. Displacement has barely changed, but output has shot up by 100 hp to a tantalizing 500 hp-and in the process, that magic 100-hp-per-liter that has long been an M division forte has been achieved. Torque is up, too, with 369 lb-ft concentrated in the first half of the rev range.
The V10's fundamentals are much like the old V8's: 90-degree architecture, aluminum construction, four valves per cylinder. But numer-ous refinements have been made to the internal structure, variable valve timing (Double Vanos in BMW-speak), electronically controlled individual throttle butterflies and in-house-develop-ed engine management system designed to sharpen throttle response.
Rather than resort to forced induction like rivals AMG and Audi Sport do with the E55 and RS6, respectively, BMW engineers rely on a heavy dose of revs to achieve the 25 percent increase in power. If rumors circulating at the M5's unveiling at Geneva in March hold true, the new engine will rev close to 8500 rpm in production trim.
M division development boss Gerhard Richter masterminded the V10, which is also earmarked for the M6 due out next year. "It really is quite special," Richter says. "There are some trick internals that let it rev quite high. You won't be disappointed!"
Proof of this is reflected in the acceleration. With a projected 0-to-60-mph time around 4.7 seconds, the new M5 is a full 0.6 second faster than its predecessor. Even more impressive is its 0-to-120-mph split, which is put at a sports car-like 12.7 seconds. Like all M cars, top speed is limited to 155 mph, although Richter hints it would be capable of something closer to 185 mph.
A new seven-speed version of BMW's sequential manual gearbox, based on the six-speed the M3 uses, will be offered as an alternative to a more traditional seven-speed manual. SMG actu-ation is via twin paddles fixed to the steering wheel or a stubby, chromed-topped gear lever. As in the M3, the driver can choose from among 11 different programs-five automatic modes, six manual ones-to alter the gear-change characteristics.
The M5's substantial power is channeled through a beefed-up version of BMW's limited-slip M differential. It measures the difference in wheel rotations left to right, and apportions power via an electronically controlled clutch, depend-- ing on traction levels. The trick rear axle is allied to a fourth-generation version of BMW's Dynamic Stability Control and Traction system.
Underneath is a reworked rear-wheel-drive 5 Series platform beefed up with components taken from the flagship 7 Series, including parts of its rear axle and brakes. Dry-sump lubri-cation allows BMW to set the engine aftward and closer to the ground than the standard inline six and V8 engines offered in the 5 Series. Weight distribution is 50/50. The entire load-bearing structure forward of the A-pillars is made from a mix of aluminum and lightweight high-tensile steel. Still, BMW remains tight-lipped on actual weight until closer to the production version's unveiling at the Paris motor show in September. Our estimates put it around 3900 pounds.
BMW used the demanding N
Well, it's too bad about the Bangle butt!
I still want one though, provided it can be had without i-drive.
Great pics
Thanks Thai -
I think BMW's latest styling exercise, 1st seen on the 7 series, is not going over well with the BMW people. With that said, I don't feel so guilty not caring for it either. I don't think the 7 looks very good, the 5 doesn't look much better, but the same cues look pretty darn good on their new 6 series coupe. Fugly wheels, but a cool lookin' car.........
Re: Great pics
EXTEX said:
Thanks Thai -
Don't forget, there's gonna be a M6, based on the 6-series coupe.
BTW, I-drive is standard.
I don't care how well the new 5 series drives, or how fast it goes, it's still butt ugly. Idrive sucks too and it's time BMW recognized the fact...
The last generation of 5 series cars were beautiful vehicles to look at, wonderful to drive, and I dreamed that one day I might own a 540. I don't have this fantasy any longer.
I just can't see spending this much money on a car that I hate to look at and can't adjust the climate controls on without pulling over to the side of the road or, memorizing the correct sequence on the Idrive.
Came across this last night and got giddy with excitement. Something about a BMW Motorsport V10 gets me goin.
http://www.germancarfans.com/news.cfm/newsid/2040702.007/bmw/1.html
The iDrive is not nearly as bad as people seem to think, the very first instance in the 7 series was deemed too confusing, so BMW quickly redesigned the interface to be easier to use. I've personally drive the 5 series and its very simple to understand and use. Most of your controls are still on the dash like an ordinary car, and the more complex adjustments are in the iDrive. Even so, if you want to set the climate control to something more exact than just the temperature, you just push the dial in one direction to get to the climate control and you're there.
Are the M cars made in a different place and by different workers than the regular cars.
Is there a special engine oil required for the new M5?
Uah, seeeexy...
The 5series is much better than the 7. And who cares, its an M5. 7spd Manual? No thanks, I like to shift, not THAT much. I also don't like SMG at all. I test drove an M3 about a month ago with 19" SSRs and SMG and I just didn't like the way it shifted. Yeah, its faster but I would rather row my own. I drove it right after a G35 Coupe with the brembos and had a lot more fun. I also felt almost scared driving it. It was a far surpirior car but I have to say I had more fun with the infiniti just because I wasn't scared to play a little I guess. I'm sure things would change if I owned it but. Just something I noticed. My best friends dad is a BMW NUT, hes gotten two 7s since they came out (the second was the sport) and his wife just got the new 6 convertible last weekend. I haven't gotten to play with the iDrive yet much but I did get to play with Audi's version and wasn't too turned off by it. But, i'm a nerd like that though. I think BMW is a step ahead of everyone else. As much as we don't like to be surrounded by computers, its going to happen more and more. So get used to it boys! Us toyota folk can't say much either. I played with a Highlander with navi the other day and it was all, you guessed it! Computer Based. Even the climate controls and all of that. I thought it was a little inconvienent but liveable. I like the touch screen idea better, but I haven't lived with both so I can't say for sure.
Just my .02
oh, I almost forgot... I don't like the wheels in silver, they offer the same thing for the regular 5 but a size smaller (it might be the 7 but not sure, I know ive seen them on something other than the M5 though). I like the darker color MUCH better. :)
