New Eibach complete lift kit
i wonder how this is different from the toytec setup of the past because they used eibach springs for their lifts.
Looks like a quality setup. The only concern I’d have is there doesn’t seem to be any spring rate info, which for some is important. For example, I carry a lot of tools for my work, so the rear was sagging on mine. After a ton of research I determined that OME 2895E springs would handle the weight, and get the stance I was looking for with my mild front lift (Tacoma Bilsteins and springs). That is a great price for everything, but without knowing the spring rates, I wouldn’t chance it for my situation. Stock setup, definitely would a contender though.
I have the same lift on my 2006 4runner, i like it the ride is smooth way better than stock. The stock suspension was bottoming out on the slightest bumps. Also keeps the cv axles straight as long as you keep it at the first notch like the instructions say. You still have adjustment room to add heavier front gear (ie offroad bumper, winch, batteries) adjust to the next level when needed
However, it does still have a slight rake. i'll take pictures to show you and post it up
Thanks . That pic you sent, is that with the lift?
D'Angelo
