So finally got the head gaskets installed on my 93 4R 3.0. It runs great but I did notice that the oil pressure gauge doesnt go past the first tick when at speed(75mph) and almost doesnt read any at all when idling after the engine is warm. ANy know issues with the oil pump or screen? Guess I will have to check the oil pressure Monday with a gauge. Drove the truck 40 miles home and it ran great. Around 50mph the steering wheel shakes a bit. Looks like the steering recall has been done to it and the front end seamed tight when it was in the air. Gonna check the tires Monday also..maybe rotate and balance them then align it. I also have to get the window switch apart and take a look at the connection. the passenger window will go down when using the drivers side switch but wont go up unless I jump the p/s switch with direct power. then gotta fix the rear sag and throw on some new shocks. Monday going to change the trans, rear and front diff, brake and power steering fluid. Anything else you all can think of? Think I am doing pretty good so far...500 for the truck, 250 for the Toyota head set and 350 bucks for the labor.
