Andrew_I said:Well what i have read up on the s/c i do not believe there are many fuel problems with them until high speeds are reached. The first upgrade i would make would be either a new fuel pump or a fuel booster. The other thing that could need to be changed would be the ecu unit which you may want to upgrade to an adjustable unit. Id check out gadgets site. http://www.gadgetonline.com/
You will need nothing more than a simple fuel controller such as an Apexi S-AFC (super air flow converter). This will let you richen and lean-out the fuel curve in 1K rpm increment's. Although it's NOT rocket science with any "blown" engine I recommend putting it on a dyno that read's a/f ratio's so you KNOW where you need to "tweek" the fuel curve's at.Ron Helmuth said:I believe a 7th spark plug is introduced to help properly burn the increased fuel load-it's not a cheap proposition by any means....
[/B]
I finally checked out the URD kit and found that it's user tuneable so please disregard my uneducated :bash: reference to the S-AFC.Finelygotone said:If it was mine, I would go with the URD 7th injector kit (with a 255 pump) and the optional AFR and then schedule a day at a good dyno shop with a wideband to determine what else needs to be done to tune....
Unfortunately not as a lady in a BMW 7 series ran me off the road onto a median and it bent the frame.Finelygotone said:That Corolla is trick - do you still have it?
