I've installed an aux fuse box over the weekend and with the various leads that are coming off it into the cab to connect to switches, I need another hole in the firewall.
Looking up under the driver foot-well it appears that there is a plastic separation between the lower dash and the upper dash. is this correct and does the main wiring loom come in higher up under the dash?
Has anyone drilled a second wire-loom hole on the driver side? If so, where did you drill it?
Thanks!
Okki
Thanks!
Okki
