New rear shocks
Cronoscr
Hello friends, I'm going to change the rear shocks , back I'm lifting 3 ",
I think I buy these TM72215007 trail master , they are basically the same as these 321513 procomp, What do you think?
Garbage shocks. Get KYB shocks if you want quality for that price. Or spend more and get Bilstein.
friends do not know how to find my new shocks, according to the law for a lift of up to 3 " should measure approximately 23" extended, is it true?
If you are using just a spring or spacer lift, stock length shocks will be fine.
With those types of "lifts" you are just raising the ride height, which doesn't affect the shock length.
thank you, for now if I walk the original springs with spacer lift, I have to change shock (are damaged) I would like some that serve me when I remove the spacer and put a higher spring
You could call toytec up and see if they will sel you just the rear shocks from this kit.. or you could get the old man emu rear shocks..
https://www.toyteclifts.com/bk9602-3-lift-toytec-bilstein-kit-for-96-02-4runner.html
Just found the billy shocks on wheelers Offroad.. they have an option for the 3” lift.. here you go.. I think they will be doing a Black Friday sale next week if you can wait just FYI..
https://wheelersoffroad.com/i-25489...r-1996-2002-4runner.html?ref=category:1388356
You can use the rear shocks from a land Cruiser FZJ80 they will be longer. I believe something in the 14" compressed to 23" fully extended range.
If you search for them I just use 1994 that would fall in the correct years that work. A centering washer will be required to do it properly. I have the KYB gas adjust for land cruiser on mine.. they ride pretty darn firm. Only used them because I got them for free.
https://www.autozone.com/suspension...as-a-just-shock-strut-rear/751636_178285_7413
Hey man, don't listen to the guy who said you use the stock shocks for lifted vehicles if it has a spacer. That doesn't make any sense.
You can try the Land Cruiser shocks, they are stiff, but they handle bumpy roads better the faster you go. If you have a lot of weight in the back, they work better.
Toyota Land Cruiser 80 Series Shock 48531-69417
C-15"
E-23.3"
Approx cost: $45-55/ea
Notes: Will need 3/4" Fender washers (2 per side) or correct Land Cruiser bushing washers (90948-02144 x4) and you will need to reuse or order the centering washer from the 4Runner (90948-02119 x2).
thank you very much to all, in my country it is something complicated, then would be to ask those of land cruiser 94 forwards to put them back?
Talyn
