New SR5P -help with wheels and tires.
Rgreathouse
Good morning we just replaced our 2004 Limited with a 2018 white SR5 premium. Love it and can't wait to start modding! I have done a ton of reading on this forum and have learned a lot but looking for some help deciding on wheels and tires/ suspension.
My original plan was 17x8 replica trd pro wheels, 265 bfgs, and bilsteins at 1.75" with a 1" cornfed. This is a great looking setup but I know i will be wanting more shortly afterwards and love the looks of 285s on a 5th gen.
Problem is that i do not want any rubbing at all and I do not want to do much trimming if any at all. I would just go with 275s if they offered a C rated 275 unfortunately they do not. So is there a perfect combo for 285s with no rubbing and minimal trimming? wheels, tires, suspension?
It seems that most folks either are dealing with minor rubbing or a decent amount of trimming. Which if that is the case We will just keep the 265s.
Thanks for any input!
Hi Rgreathouse,
Using the search field at the top of the page is a GREAT feature and a very valuable asset! Here are many of the threads from the forum library... Enjoy!
http://www.toyota-4runner.org/gsear...runner.org/5th-gen-t4rs/&ss=15024j12093778j24
rig, Cheers!
I've done lots of searching just haven't found an answer I like! Which most likely means that there isn't one. Ill probably end up going with 265s 1.75" bilsteins with a 1" cornfed for now.
No pain, no gain. BFG 275's barely and I mean barely rub and only in full lock reverse. Nothing that 5 minutes worth of pulling the inner liner forward didn't fix.
Rubbing is a given, but easily fixed with little effort. Don't let that deter you from making some great changes to your rig.:nod:
Here's a set of 275/55 R20 Good*Year Eagle LS-2's NO LIFT!
They rarely rub unless I CRANK the steering wheel to the stops while hitting a parking lot ramp HARD!
...but most of us here have gone bigger wrt tires & wheels w/o complaints! 'Best to you',
rig
you'll get mild rubbing on the body mount with 285/70/17s on a stock suspension. You'll need to push your fender liners fwd and trim the excess bumper. you will have a bit of rubbing in reverse at full lock.
If you add a 1.75 lift in front, you should be fine.
youngrk
