New suspension and shocks question
4wheeln98
ok going to knock out a bunch of birds with this thread, so...
I'm looking on performance products at the 1" lift springs. I don't wanna go to extreme with a lift and keep my tires and wheels. Also considering sway bars by ADDCO will i need to get front and back or either one? And i will be needing new shocks. What's a good brand that will go along with new springs and sway bars.
Any input will be appreciated. thanks!
If you're going to get the PP springs you really should get the Bilstiens to go with them since that is the only aftermarket shock that works well with them as they are designed to work with the Bils and the springs are made by H&R over in Germany for PP.
What's your measurement from your wheel hub to the bottom of your fender flare?
Sway bars are nice on the street but if you plan on any off roading you will lose alot of the flex but you can disconnect them.
I wouldn't mind a little better handling but around corners mine does fine on the new OEM coils and shocks and since it's a '99 the coils have one more wind which is almost 1" taller than other 3rd gen Runner coils. I wanted the Bils/PP combo but it wasn't in my bank account as I got the OEM stuff under $400 shipped and saved a couple hundred.
