New suspension, clicking noise
dmalis12
Just put on new suspension, FJ coils and bilstein 5100's up front. It sounds like a faint clicking when i go over small potholes or curbs. Almost like something is loose but I've checked everything. Anyone had any similar issues like this. Please advise. thanks.
Make sure you can move the coils around in the coil spring assembly. If you can, remove assembly, compress spring some more, and tighten lock nut. Good luck with diagnosis.
It was partially skid plate but found that noise still continued, found that it was the front sway bar link being loose. There is a 6 hex that is to hold the thread in place and i didn't know. I found a great picture that describes below. Can believe one little bolt made all that noise
DevinG93
