new to the 4 runner club lift question
fullforce
Just bought my first 4 runner and love it to death!
2005 v8 4wd but the factory stance is killing me and it needs a set of tires so I figured id raise it up a little and go up to the next ive done alot of searching and for now i just wanna do a 2/1 lift cheap and 265/70/17s
I was looking at this on ebay and wanted some opinons?
is the diff drop necessary for only a 2" front lift?
thanks
Steel 2" 1" Lift Kit w Skid Plate Diff Drop ¦ FJ 4 Runner 05 14 4WD | eBay
diff drop isn't necessary, you'll find that once you do the lift your cv's will actually be basically parallel to the ground, and hardly angle downwards at all
This^^
Don't waste your time on a diff drop. At 2" lift, the CVs will most likely be level. I would recommend going with Bilstein 5100s all around if you're on a tight budget. I would also recommend going with FJ springs if you can afford it.
thanks guys I guess Ill but it and report back on the quality, on a older truck I had bought some daystar poly (rubber like) spacers and they didnt last very long before they broke apart, The bilstines do seem like a good bang for the buck witch I could always add later.
youngrk
