New UCA's/Tires/Lift, now drives like crap
The more you lift, generally the worse the ride is going to be.
the front geometry is optimized for the LCAs to be about level, and when you lift, they angle downward. The more angle downward the LCAs have, the more they have to scrub outward on compression, following the radius to their mounting pivots on the frame.
I have an arb bumper with a warn 8274 winch mounted up front. I was playing games like you are now and I finally just ordered OME heavy front coils with their stiffest strut. This solved all my issues. arbusa website has a chart for this.
Your arb weight is the problem and you're not picking the correct solution by playing with struts, springs, and spacers that are not designed for that amount of weight up front.
nothing you have on the front now is going to solve your issue.
