New Unimog info
NoDak
Senior Member
http://truckyeah.jalopnik.com/forge...-unimog-just-got-even-bett-1695992203/+damon#
lol 47" of water fording which is more than a foot more than the JK Wrangler.
A new OM934 "BlueTech 6" 5.1-liter four-cylinder diesel, moved to a mid-engine position as of the Unimog's 2013 redesign, makes 231 horsepower and just over 660 lb-ft of torque which Mercedes says comes all the way on from 1,200 to 1,600 RPM. Top speed is limited to around 55 MPH, but you'll get your kidneys smashed to bits if you go that fast on the terrain this truck was built for anyway.
The engine and (/or) transmission can be switched to power other devices, construction implements, and so fourth whether the truck's being driven or not. Eight forward gears, six reverse gears, and an optional "off-road group" range of gears maximizes the hell out of the engine's efficiency at any speed.
The new Unimog's also been tuned for better fuel efficiency and lower emissions, but that's not nearly as cool as the trick new "Tirecontrol Plus" central inflation system. With a set of preconfigured tire pressures, drivers can just flick through "Road", "Sand," and "Rough Terrain" modes to inflate or deflate at will. Sort of like terrain-response tech in a Land Rover or Jeep.
The Unimog's frame and the tubular crossmember are welded to allow 600 mm of torsional flexibility in off-road driving. Axles can articulate up to 30º thanks to torque tube driveshafts and coil springs. The torque tube and torque ball allow for more flexibility between the transmission and axles, which allows the axles to perform insane contortionist circus tricks while continuously pushing the truck forward.
Portal axles, which are basically adapters that let the axle be mounted above the center of the wheels, help the truck hit insane approach (44º) and departure (51º) angles. Breakover is an impressive 34º.
The U4023 and U5023 Unimogs can climb a 45º grade and ford 1.2 meters of water as previously mentioned; which translates to over 47" in Units Of Freedom. That's a foot deeper than a JK Wrangler is rated for and would drown just about anything else twice over.
Mercedes might be building their own take on the Lincoln Blackwood with their new pickup, they might be building a venerable work vehicle, or both. but let there be no doubt in your mind: Mercedes can build a serious rough-country commercial truck when they want to.
The Unimog is the ultimate off road truck. Not even the Hummer can be in the same breath.
In Germany outside of Stuttgart I saw a Unimog pulling rail cars down a track, dock them, lift up its rail wheels, then drive off. The yard operator told me the Unimog can tow about 25,000 kg (I think 55,000 lbs) and use them to move rail cars all over the yard.
I did get to drive in one outside Vegas, where we took a wheel climb at about 35 degrees.
I wanted to drive in the Mercedes Brabus G63 6x6 last year but didn't get to:
https://www.youtube.com/watch?v=mQR5yl8PrCM
I have wanted a Unimog since I was 6 years old (I had a Matchbox Unimog as a child - by far my favorite Matchbox).
I currently have absolutely no practical need or use for Unimog but they're still damn cool.
It's not new, but check out the Unimog at Breslau video from the Breslau Rallye:
https://www.youtube.com/watch?v=Q0pBYCPEe3E
With that kind of weight and a factory snorkel, you'd think it could go full submarine mode. :D
seltzernator
