I wish this was my engine bay pic! Same color runner though!!!
Quoting Gadget@URD "Performance flow data shows that the performance is very closely mirroring the performance levels of the Tacoma MkII Stage I configuration. We are very pleased with that."
Info found here.
URD 05-08 XRunner/Tacoma MKII-E Stage I Supercharger System
The Stage I Kit is a MKII kit installed on a completely stock truck. It includes:
* 80mm pulley
* 5700 RPM limit
* URD's 2005 XRunner dyno results showed 337 RWHP and 315 RWTQ at 5700 RPM & approximately 7 PSI of boost
Stage II is achieved by adding:
* 75mm pulley
* New Stage II calibration file for the X-1 engine management system
* Doug Thorley Long Tube Headers
* URD Competition Y Pipe
* URD 3" Cat-Back Stainless Exhaust
* URD's 2005 XRunner dyno results showed 382 RWHP and 352 RWTQ at 5900 RPM & approximately 8.5 PSI of boost
Stage III is achieved by adding the following to Stage II upgrades:
* 70mm pulley
* New Stage III calibration file for the X-1 engine management system
* Installing the Grill Craft MX Series grill to improve airflow over the front mount intercooler.
* 93 octane recommended, however highest power levels will be obtained by using high octane unleaeded race gas
* URD's 2005 XRunner dyno results showed 400+ RWHP and 382 RWTQ at 6200 RPM & approximately 10 PSI of boost
All dyno tests used a 2005 XRunner with 75,000 miles on it and used a Dynojet Dyno.
Recommended vehicle upgrades for the increased power level:
* Install OEM Toyota engine oil cooler. This engine oil cooler is stock on some Tacomas with Toyota's tow package. If your truck does not have an engine oil cooler, we recommend installing it to stabilize engine oil temperatures, especially in hot environments. Toyota part numbers are included in URD's MKII installation manual.
* If your truck has an automatic transmission, URD recommends upgrading the transmission's valve body so it will better withstand the additional power levels. Contact Import Performance Transmission for information regarding their auto transmission valve body upgrade.
* Grill Craft MX Series grill to improve airflow over the front mount intercooler.
Note: URD logo may not be painted on intercooler. Features and specifications may change without notice.
