Newly rebuit 22re questions
JBird
Last weekend I istalled a rebuilt 22re into my 1988 4Runner. I know that engines lack performance when new but I have a feeling that there could be something slightly wrong. Engine timing is spot on, valve clearances are set...
1. I have almost no low end power, even with a higher torque cam installed, and oversize valves.
2. When accelerating there is a noticable pulling feeling, like quick bursts of power. Its slight but I know it wasn't there before. I think it could be something with the EFI.
I have to say the engine only has about 30-40 miles on it so far, so it could very well be just new kinks that need to be worked in. If anyone has experienced this with a new engine, advice would be great.
Oh yeah, and the cat was replaced as well...was almost completely clogged.
Thanks for any help. - JR
Not sure what to tell you, but you might want to check into fuel stuff like you said. I rebuilt my 22re 4 months ago and when I first started it up it had about the same power as before, but has gained some ever since then from breaking in. I put a high torque cam also and haven't run into that problem.
