Nitrogen filled tires?
CobraSpdRH
Anybody here have nitrogen-filled tires? I didn't think to ask when I bought mine at the dealer, and I noticed it has the green caps at all 4 corners, which leads me to believe they may have filled with nitrogen. If so, can I just add air to these when the pressure gets low, or do you have to refill with nitrogen only?
Or is there a way to check and know whether or not it is indeed nitrogen? Thanks
I have just over 78% Nitrogen in my tires. Otherwise known as the air we breathe.
In a consumer car application, it's mostly a money-making scheme. In other words, most places will charge extra for a 'Nitrogen fill", and the benefits are overstated.
Nitrogen molecules are larger than Oxygen molecules. So there is a slight benefit of possibly not losing as much air pressure in your tires over time if you inflate with Nitrogen.
I've heard some claim that the pressure inside the tire won't vary as much with pure Nitrogen, as compared to the air we breathe, which as previously stated is already 78% Nitrogen.
Tests I've seen indicate that the pressure inside the tire varies almost exactly the same amount between the pure Nitrogen fill and the 78% mix we breathe, when both tires are subjected to the same ambient temps.
Another consideration with filling with ambient air, is that over time, as the smaller Oxygen molecules potentially leak out, and we put more air in to compensate, the percentage of Nitrogen in the tire increases over the 78% that was present, when it was first filled.
Places that fill tires with Nitrogen, mount the tires and inflate them in the open air. So you'll never get 100% Nitrogen, because when mounting the tire ambient air will be present in the tire. The only way to get 100% Nitrogen, is to mount and inflate the assembly in a vacumm, devoid of any oxygen.
The only application that really benefits from a Nitrogen tire fill, is in aircraft. Because if there is a fire in the Plane at altitude, and the tire burns and bursts, the last thing you want is oxygen in the tire itself, contributing to the blaze.
Just for the sake of the discussion, I've studied Nitrogen in tires extensively, looking for any possible benefit that might positively affect our results on the Racing Team I'm a part of. In our extreme use case, it didn't matter one way or the other.
The bottom line for consumer cars is that it certainly won't hurt anything to get the "Nitrogen fill", but any benefit is so slight to nearly non-existent, that I'd only do it if they did so without charging extra.
To answer your question, there will be no problem adding regular compressed air to your tires, if the pressure in the tires drops.
Suck some of the air out of the tire, and see if it makes your voice high.
Oh wait.....that's helium. LOL.
I agree with 02SE completely. My brother and I were talking about this a while back, in reference to tires on the Formula SAE race car his team was building...and made the same conclusion.
Just keep filling your tires with regular old air. The smaller molecules will escape first, leaving higher concentration of nitrogen behind. You my friend are on Zeno's ladder the free nitrogen filled tires!
If you are a smoker then you should probably fill your tires with pure hydrogen. This will give your truck a burst of energy at some point in the future.
On second thought, don't do that.
My girlfriend and some of my buds have bought tires at Costco. They come filled with nitrogen and they do free refills. But I agree with others, in that, I wouldn't pay extra to put nitrogen in my tires.
The nitrogen from Costco seems to not need filling as much. My Costco puts on green stem covers so you know it has nitrogen in them.
It's a pain in the ass because the places where you need to ask for help are usually busy around here, so I prefer the self-serve air, not to mention the cost.
Thanks for all the replies guys. I agree in that I see no actual benefit to the use of "nitrogen" in tires, just wanted to make sure I won't upset the cosmic balance by putting in regular old air. Thanks for the confirmation.
As a marketing guy myself, I have to hand it to those marketers who convince people that they have to go out and get the latest and greatest or they are doing a disservice to their vehicle. I will just throw in some Z-Max, slap on a Tornado and call it a day :)
Tires do stay properly inflated longer with nitrogen. Since I air down when I wheel, I'm constantly changing/checking my pressure.
In our street car I also just run compressed air.
I look at it as part of my normal checks along with oil level. Maybe I should put nitrogen in my crankcase! j/k
I do notice a pressure drop when winter hits from the cold.
Back to your true question. No you are not going to upset the balance of nature by mixing nitro and compressed air. Yes, mix as needed. You will just reduce the benefits of the nitrogen.
As long as you change your air out when we go off of daylight savings time you should be fine. If you don't, your air will be "off" by 1 hour which can cause tire failure.
Also keep in mind that if you ever go to Canada, you have to stop at the first gas station and let out all of your US air and put in Canadian air. This is because Canadian air is measured in KpA and US air is measured in PSI and is not compatible with Canadian air.
If you are just taking a short trip across the border, this isn't an issue but if you are going deep into Canada you will either need to swap out your air or carry a set of Canadian-spec tires with you to put on while you are driving in Canada.
Glad I could be of help! :D
I buy all my tires at Costco so Nitrogen is free for life.
Don't know if it makes much of a difference but certainly doesn't hurt.
