Hi -- Does anyone have any experience of replacing this pipe? Mine has a small leak on the elbow of the small pipe that carries the Cold Start Injector pipe. I've tried to seal it with Plastic Metal, but it's gone again.
A simple fix to braze over the leak hole, but first I have to remove the whole By-Pass pipe. Only trouble is you can't get to it because it runs behind the block rear surface & the bulkhead. Can't see how to remove it, or what has to be taken off first ....
4Runner is off the road & I'm stuck. Any clues welcome.....
Have bunged hole up with more Plastic Metal, as I can't remove the pipe. Have done something naughty in the process........
Leak stopped, but have screwed up somewhere. Removed rocker cover & throttle body to give myself more room. On re-assembly, engine won't idle at all & runs very badly below 3k RPM. Perfect before I dabbled... Not driveable in a remote, hilly area on narrow roads.
Is it important that I've removed the Cold Start pipe from the throttle body? Do I need to bleed or prime coolant?
Colin in the UK
Colin in the UK
