No lights
Chris98t4r
Hey guys need some help here. The lights in my climate control unit don’t work as well as the clock and the light around the ignition key. Both dome and acc fuses are fine. Are these common failures or am I missing another circuit feeding these items. Any thoughts are appreciated
The lights are common failures. The clock is also a common failure. If you removed the clock and take it apart carefully there's a few springs that you can stretch a little then put back together and it should work fine.
Sometimes if you tap on the the climate control plate and the light bulbs come back on, its time to replace them. They are super easy to change and you can do it in a few minutes.. :-)
DionicioLives
