No Man's Land - High Island to Sabine Pass (SE Texas)
Canazes9
South east Texas doesn't offer a whole lot of public off roading opportunities. There are about 30 miles of public beach that can be driven between High Island and Galveston. The sand on a lot of this beach is quite deep, stuck vehicles are very common. The beaches are pretty and the surf is gentle.
Texas Hwy87 used to run between High Island and Sabine Pass - two hurricanes in the 80's and 90's wiped it out and it has never been rebuilt. The McFadden marshes north of this area are wildlife sanctuaries and there are no roads, no public access. The area between High Island and Sabine Pass is now literally - No Man's Land! The only way off of this ~20mile stretch is to drive off the beach in one direction or the other, the marsh is fenced out.
I had never attempted this stretch until today. My wife daughter and youngest Schnauzer loaded into my '12 Tacoma DCSB Off Road. My son and his friend and our old Schnauzer loaded into his '07 DCSB Off Road Sport. I hope I can be forgiven for leaving my wife's new '13 T4R SR5 at home. The T4R is still completely stock and I wasn't sure what challenges we would be facing (more on that later). We brought tow straps, high lift jack, wood for the jack a couple longer 12" sect to drive on if necessary, full ice chest, chairs, beach canopy, sunscreen, bug spray and my VIAIR 450P:
Can't say enough good things about the VIAIR 450P, worth its weight in gold! Fast, quiet, compact, will fit behind the rear seat in the Tacomas. Airing down to 15psi means the difference between walking through deep sand without spinning a tire and burying it up to the frame. Can't understand people buying $25,000-40,000 4wd, spending another $2-10,000 (or more) on customizing, then refusing to drop a few hundred on a quality air pump! A high quality unit like this will have you re-inflated and on the road in 10 minutes or less from the time you stop to pull it out...
Back to today's trip, we started off by driving down Texas hwy 124 till we hit the beach just south of High Island. We turned east (left) on the beach and pulled over and aired down. Reset the trip odometer, dropped into 4Lo (mainly to make it easier to creep) and drove off at about ~10:00 am. The beach sand was packed for the 1st mile or two, getting progressively deeper and looser the further east we went.
The sargassum weed is blowing on to the beach right now and it is piled quite deep from just above the surf line. Generally speaking there are two paths available - the beach path, directly on the beach or in the sargassum or slightly higher up there is a sandy track that appears to be just above the normal high tide mark. We mostly stuck to the beach whenever possible, only deviating up to the upper sandy track to avoid some of the thicker clay areas (more later...).
After about 5 miles we stopped on the beach, put the canopy and chairs out, threw frisby, swam, etc. The beach here is not nearly as nice as the areas further west particularly Gilcrest to Galveston, but still, not too bad. It was made nicer by the fact that there wasn't another vehicle in sight!
The weather only called for a 20% chance of rain, but a little thunderstorm was bearing down on us so we decided to load up and move on down thinking we would stop again somewhere further down.
A few miles further down the beach started to get thinner and clay started to appear. 1st as strips, then in the form of large boulder like formations. This started to appear about mile 8:
The dogs seemed to enjoy it!
About mile 10 there are the remains of what must have been a nice pier at one time or another. Sorry, I forgot to snap any pics! There were two couples camped out there in tents w/ a Hummer. They must be a lot tougher than us because the mosquito's were beginning to get thick! A little further down about mile 11 the clay started appearing thicker and more closely together.
I stopped and shot some video of my son going across some of the sargassum covered clay. It's a terrible video, too close, terrain is still a little boring, but I thought I would shoot more later...
(click the pic to view...)
We pulled over after this for a quick break but became dizzy from the loss of blood and decided to move on in search of less mosquito infested areas:
At about mile 14 we came across this:
The mosquito infestation discouraged us from getting out to investigate. Oddly, the mosquito's weren't an aggravation when riding in the trucks even w/ the windows down, but were brutal when you got out to walk the beach. We became weak willed in our plan to shoot more video and settled for snapping pics while on the move in the trucks. The terrain was becoming progressively more difficult, more clay hills/boulders (whatever you call them), less beach to maneuver in:
After about mile 18 the beach began to widen up. Further up the beach a trail leading to the north revealed a strip of asphalt! I turned up the trail and on to the welcoming asphalt! After a mile or two the asphalt was blocked w/ barricades and truck loads of steeply piled sand. We turned around, went back out to the beach and drove out of the beach. The odometer read 22.3 miles (inflated by our mistaken run down 87) when we pulled off the beach at 2:45 after a quick stop to pull somebody in their 2wdF150 out of the sand. There is a public beach access here where hwy87 is barricaded off. We stopped and aired up:
All in all, a fun trip! So what would I do differently? Well, next time I run will start from Sabine Pass and drive west. Early in the day you are eager to drive and to conquer rough terrain. Later in the day you want to relax and enjoy a pretty beach. Driving west to east puts those things reversed. If we had started at Sabine Pass and drove to High Island, I probably would have made the easy beach drive of another 10 miles to the pretty beaches in Gilcrest that are relatively unpopulated. I would probably still be sitting there instead of typing this....
The other question everyone has is "Do you think my XXXX could do this?" I think any decent 4wd truck can make this drive, without lift and without off road tires IF YOU AIR DOWN!!!! The sand is deep in a lot of places! Even 4wd vehicles get stuck easily in deep sand with 40psi in the tires, drop it to 15psi and most will roll through with ease.
A different time of year w/ less sargassum weed might be more difficult to drive in - the sargassum seemed to help a lot! Driving in the rain on that clay probably would be a lot more challenging as well! Finally, I've seen pics of people driving around on those clay boulders (whatever they're called) - obviously we couldn't do that, but if the tide was lower, probably would have been possible. If that's an important part of your experience you may want to check the tides.
I don't regret for a minute bringing the recovery gear and going w/ a buddy truck! This is a desolate area, very few vehicles, no cell phone coverage. As evidenced by the truck buried in the sand - if you screw up out here, you are on your on, better be prepared!
David
lahflafiofiafjafoia
Sounds like fun. Have you heard of people driving in the washed out road instead of beach?
The washed out road is the beach. Seriously. There are chunks of asphalt all over the beach. The beach has eroded back to where the highway used to run. 20 years or so ago I'm sure it was different, but erosion has taken it's toll. That strip of asphalt I mentioned the last mile or so to Sabine Pass is the only thing remaining of hwy 87 and it's only about 100 yards off the beach now. The fence I mentioned separating the marsh use to run along hwy 87....
David
If you watch the video, the very first instant that the counter flips to 17 sec. you will see a chunk of asphalt in front of the left front tire. I believe the little ledge you see is the partially washed out road bed of hwy87 - it's 25yards from the gulf there....
David
Made another run Friday, ran the beach/clay rocks the whole way. Started at Sabine Pass this time, drove to High Island. The Suburban is still there, sunk a few more inches, looking a little worse for wear:
Dogs thought it was too hot to be out there...
David
A nice little trip I have made numerous times for duck hunting, and getting away from the crowd. Be wary, though, about half way between High Island and Sabine pass is where the nudists camp out and call it their own (usually on the weekends). I ran past a group of 15 or so and it wasn't pretty. Haha
Let me know if you are going to make any other runs. We need to get Yota owners together down here. I am in BC.
Take care,
Jeremy
I
Take care,
Jeremy
I
We did see a few nudists this last trip - mostly they kept to themselves as we came by.
[MENTION=62425]Ryan1975[/MENTION] indicated he would be interested in making a run also - I'm up for it, maybe early September?
David
David
I would love to. I'm up in Ft Hood area with a lifted 4Runner TE. Just need to get permission from momma first.
Okay, so we've got some interest in making this run!
Next dates I see available are Sat 9/21 or Sat 9/28.
How about it @Ryan1975, @WhiskeyTango0311 and [MENTION=66483]hrod79[/MENTION] ?
One of those dates work for ya'll?
Let me know...
David
Let me know...
David
The oldest is Varsity Football and with the 20th being a Bye week, this feels like a better weekend for me. Let me get with household6 and ask.
I'd be staying in Houston near Deer Park, googlemaps shows an 88mi/1.5hr drive from my start point in the morning of the 21st to Sabine Pass or 70mi/1hr10min to High Island.
I might also have a friend that would accompany us with his Tacoma from another board. I'll contact him and see if he is game.
I will get shackles for my truck and will look at a front receiver hitch if I can get that in time. Otherwise this should be a pretty low threat drive I'd imagine (short of a hurricane hitting).
You should have recovery hooks on the front of your TE - No?
I've got and will carry plenty of recovery gear - 2 tow straps (1 hook, 1 loop), 3 Recovery straps (3 different lengths) shackles, warn receiver shackle hitches (2), hi-lift, blocks of wood for operating hi-lift in sand, short handled shovel, 8,000 pound come-along, Viair 450P compressor.
I'll bring all of it with me. I've never needed anything but the compressor for myself, but I've used the recovery straps a lot out there for others... :lmao:
As you said it should be a pretty low threat drive and usually you can bypass if somebody is stuck in front or behind to get at them from the opposite side. I should have my wife's Icon suspension installed by then on the 4Runner, so we'll probably bring that. I've done it both ways, definitely the best way to do it is from Sabine Pass to High Island. Close to Sabine Pass till about the 1/2 way point you've got to run fairly slow - 5-10mph. From the 1/2 way point till you start seeing a lot of traffic (which there probably won't be after Labor day) you can run as fast as you feel - 20mph is easy stock, faster depends on careful reading of the sand speed bumps and your vehicles capabilities... The Fantasea is in Gilchrist at Roll Over Pass, about 1/2 way back to Galveston from High Island. Good place to grab a burger if anyone is so inclined (my wife and I probably will stop there).
David
David
Yeah, I have the front recovery hoop, but I think a Curt front receiver hitch would be more sturdy. I'll stop on the way home and see if they have one in stock.
I've got a lifted TE. Anyone else have HAM Radio? I've got two handhelds otherwise besides the mobile rig in my truck.
DSCN0674_zpsd36e1c17.jpg~original
I don't have a radio, would like to check yours out though! Planning a trip to Big Bend for Thanksgiving and I've been wondering what to do about radios....
For anyone else looking, this run is very doable in a stock 4wd - lift and tires not required, particularly if you are running with others. I ran this last weekend in my wife's SR5 T4R. I did have nice MT tires, but no lift - no problems.
David
I didn't realize that this was you:
No, was pretty easy actually. I referenced the Toyota parts from this Thread on Tacoma world:
Rear Diff Vent behind the tail light Mod - Tacoma World Forums
Walked into to my Toyota dealer parts dept, said I wanted those part #'s. They didn't have them in stock, had to order them - came in a few days later. I don't remember the exact price but they were cheap.
Initially, I was all excited thinking that was going to be the ideal spot (behind the tail light) for the 4Runner also. Eventually, with some input from folks that have "been there/done that" on this forum I realized behind the lights on the 4Runner is not going to be the best option for me and I'll probably put mine in the gas filler area as others have done.
Location is what has held me up, but I'll probably do it soon now. If you have an e-locker you will need to get a T and some additional tubing to tie in the e-locker solenoid breather. Should be able to buy a suitable T at any auto parts store.
David
(from another thread)
You'll have to show me what you're referring to.
I assume you're asking about the e-locker breather? I don't have an e-locker on my wife's 4Runner (SR5), but my '12 Tacoma does and it's very similar to the 4Runner. Maybe these pics will help...
This is the 1-way valve on the rear differential:
Same camera angle, now I'm pointing to the e-locker breather:
Here is a better picture of where the e-locker vent ties in to the cross-member underneath the truck bed:
You can trace it back to a smaller diameter piece of tubing that ties into a common plastic conduit bundle w/ the e-locker wiring and see the small diameter tubing where it exits here (visible in this picture are both the e-locker vent tie into frame rail and below it you can see the hard small diameter plastic looping out of the e-locker that is the begining of the e-locker vent line at the e-locker actuator on the rear diff) :
When I do the breather on this Tacoma I will disconnect the larger diameter tubing where it is attached to the frame cross-member and T it into the new breather line. Obviously, the stock location is a lot higher than the factory rear diff 1-way valve. Still, if you are back there and running a new higher vent already, why not tie it into the new higher location?
While these are pics from a Tacoma, I'll bet you can use them to find your stuff on the TE4Runner. If not we can look at it on the 20th.
HTH
David
David
charlesz
