no owners manual
clarence
I just purchased an 02 T4r and i love it. I have driven it 500 miles and the check engine light came on as well as the vsc, trac off. I have ordered a manual from toyota, but at the time i had no prblems. can anyone let me know what this means? i would greatly appreciate it.
Run by your local auto parts store and ask them to pull the code for you. They should be able to tell you what threw the code.
Oh and any time your check engine light comes on, the vsc & trac lights will come on too.
My lights all lit up about a month ago...turns out my gas cap was not on tight enough :D. Hope your issue is just as easy to fix as mine was!
ok just left the auto parts store. the code that showed up is p1135 could this be an o2 sensor? also when the vsc/trac off lights come on does this mean they are inoperable?
ok so im all fixed up, it turns out that the problem was a bad air/fuel ratio sensor. everything seems to be ok now. it did however cost me 270.00$ before it was all said and done. Thanks for the tips.
