No speedo
gmaneod
Gents,
My 2000 Limited had the ABS light on so I bought and had installed the ABS wheel sensors cables installed after I got the truck back no speedo any idea what could be wrong thanks?
Gary
Was the Speedo working prior to installing the sensors ? For a while I ran only 2 front sensors and the rears I cut out. My Speedo still worked. Till magically it stopped after messing with the wheel bearings. The Speedo runs of ABS as we now. There is a crown type metal ring that the sensors read. Maybe that is messed up or rusty or something ? Anyways, I gave up and installed a Tacoma speed sensor. Which is a sensor in the back of the tcase. But you need to run 3 wires , one goes to the cluster.
Gents,
Gary
You need to flash the abs codes to see what is wrong with the abs system
The speedo runs off the ABS system, as others have said. Fix the ABS system and your speedo should heal itself.
If you aren't planning on fixing the ABS system, you can put in the Tacoma speedo sensor on the back of the trans/transfer case and wire that in instead.
-Charlie
youngrk
