Noise from my 2004 Limited 4wd V8
rhamada
Hey everyone. I have a 2004 Limited V8 4x4 with 245K on her. I'm getting a hollowing / roaring noise from what seems to be the front end area but not sure. It's constantly there and I can start to here it around 20 mph all the way up to highway speeds. The noise seems to increase in speed with the RPM of the vehicle and slows down when coming to a stop.
The noise stays pretty constant and doesn't go away when I turn right or left. I first thought wheel bearings so I went ahead and changed both sides and the noise is still the same.
The noise is difficult to explain and tough to video because of so much other road and wind noise. Tires are new within and few thousand miles. It's too load too be the tires.
I can feel some vibration in the pedal and the steering wheel vibrates just a bit. I've had the wheels balanced and rotated multiple times just to be sure. End links are fairly new Proforged end links. Energy suspension bushings are pretty new. Bilstein shocks are pretty new.
I'm not sure where there noise is coming from or what's causing it to howl / roar. Any ideas or help would be greatly appreciated.
utkrstam
