Noise when turning
brenddie
Hi all, we have a 2001 4runner that began making a noise when turning to the right. Tried searching but Im not quite sure what im looking for and had no luck with the results. After some troubleshooting it seems I found what is causing the noise:
The right hand side wheel does not seem to be scratching those to parts
Im sure this is the problem as it fits. The noise only happens when turning right and when the wheel is 100% turned to the right. The noise will happen once the 4runner starts moving forward and hitting bumps causing those 2 parts to scratch.
Im assuming this is not normal and that the left wheel needs adjustment. How can I adjust the wheel to fix this problem?
