fxoffroad
On day 2 of ownership, I went offroading in the mountains w/ my Limited - I put the vehicle into L4L (action: put the vehicle in neutral, foot applied to the break) turn knob to L4L. The vehicle made some crazy noises and beeped/buzzed like a seat belt warning. Drove a little bit, then stopped - neutral, back to 4HL - and then put it back into L4L and it was fine. Figured it was the first time, maybe that grinding sound and feeling is normal?
So today - take it up into the mountains again - repeat the same steps above and the vehicle does the same thing - only VERY loud noises. Typical?
I assume the DAC is applying braking action with the same equipment/mechanical stuff that controls the Anti-lock brakes? The DAC made all kinds of noises - so bad my wing man begged me to turn it off.
Then used the DAC (which I understand only works when you're in 4 Low (L4L) and there's all kind of noises as it slows makes its way down the trail - granted only a 2% grade or so.
Is all this normal?
Is all this normal?
