NomadX kitchen and drawer system - Group Buy
bisonrunner
This group buy is to gage interest in a kitchen drawer system and control electrical control panel I have build for 4runners ,Lexus gx as well as jeep.
This is designed for the overlanders like myself that like to have an efficient, organized setup in their rig. it is pretty cool to have everything you need in the back off the vehicle, to charge and operate all your accessories and to be able to plug in you solar directly to the unit to keep the battery healthy during longer offgrid trips.
build out of aluminum extrusions profiles round or square also comes in black.
birch plywood drawers. and plastics panels for the top back and the sides
If we can reach 15 people I will give 10% discount
If we reach over 20 people I will do 15% discount
I will begin production when goals are met at the end of October
Couple options available if you don't need all the electrical setup.
1. single unit with 1 drawers with compression latch , cooktop pullout with
food grade cutting board (or 2 drawers)
-heavy duty fridge slide for your fridge of choice 50 or 65qt
41.3/8w x22h x30d
$3500
2. single unit with 2 drawers with compression latch
- cooktop pullout with food grade cutting board (can be
replaced with a 3rd drawer)
- heavy duty fridge slide for 50 or 65qt fridges( drawers will be about 1 inch
shorter with 65qt)
-Control switch panels with lcd voltage monitor and 2 USB port 12v outlet
and 6 accessories switches option(fridge, compressor, waterpump,lights..)
-solar panel wiring to car battery with Anderson plug and charge controller
(neatly wired behind switch panel and next to fuse box)
just plug in your full time roof mounted solar panel or solar blanket to the
provided Anderson connection port.
- heavy duty 4gauge 15ft wiring with quick disconnect to back of the unit to
power everything you might need.
- shelf on top of fridge for an inverter(2000w in picture) or extra storage.
dimensions 41.3/8w x30h x30d about 100lb without accessories
$5000
If you need a base plate you can use plywood or get something like goose gear would work.
I can accommodate special custom requests.
I try to use the best material possible for this and will try to keep the price and weight as low as I can.
the 4runner version is 3inch wider and 2 inch deeper than the jeep in the pictures
I am based in Los Angeles and can do local instals and wiring. for out of state we would have to freight it.
let me know what you guys think and if you would be interested in one.
you can follow my personal page on instagram @le.baroudeur
I also created a page for this product [MENTION=24312]Nomad[/MENTION]expeditionkitchen
2001ATL
