Non-rebuildable suspensions that are on par with the fox setup on 2019 TRD Pro?
MrGainzz
In your opinion,what aftermarket suspension setups that don’t require services that are just as good as the new fox suspension on the 19 Pros when it comes to on road and off road performance ? I’m thinking of Bilsteins 6112/5160,OME and toytec boss(not 100% sure if it’s rebuildable though)
Moreover ,do you consider the new fox suspension to be an entry level setup?
There probably are no non service type stocks that are comparable. Most rebuildable are also not as good in some instances. The only comparable aftermarket shocks that are plug and play are the OME BP51. Otherwise you'll need some custom internal bypass shocks to provide similar dampening.
