Pranav
Alright, I'm probably jumping the gun by asking this now, as I have yet to get the exact specs on the car hauler I will be borrowing.
My friend and I want to take a '73 dodge charger out to a 1/4 mile drag event this Saturday. However, it would be much easier for us to tow it out there (120 miles each way), plus we'd have the option of towing it back in case it breaks.
My father and I have swapped cars for the next few months, so I am driving his 2003 v8 2wd 4runner (he's fine with me using it tow). From what I understand, it has the factory tow package, but after browsing this forum and looking underneath the 4runner, I found that it only has the weight-carrying RECEIVER attached to the rear cross member. The owner's manual tells me I have a 7300lb towing capacity, but only a 700lb tongue weight rating.
Do I have any options when it comes to towing a 3700lb car, a 1300-1500lb trailer with surge brakes, and the factory weight carrying RECEIVER? I'm guessing the weight on the trailer and assuming it has surge brakes. I'll get the detailed specs on it fairly soon.
If we decide to make more towing trips for the rest of the year, we will definitely split the cost of a hidden hitch after this weekend. For now we don't have any options of modifying the 4runner before this weekend.
BTW, does the factory towing package consist of an auxiliary ATF cooler installed inline with the ATF cooler built into the radiator? I haven't had a chance to really poke around under hte hood, but I'm assuming the big plate+fin cooler is for the AT. It looks awefully similar to an aux. ATF cooler that I installed on my 4AT Honda accord that sees weekly auto-x duty...
Assuming I can actually pull the load, I know that I'll at least have to:
-Practice moving/backing up in an open lot
-Inflate the tires up quite a bit
-Drive with the tranny locked in 4, only kick it up to 5 on a flat road with no other cars in sight
-Review all of the safety tips in the owner's manual and towing brochure
-Take all the towing advice I can get
-Bring spare trailer tires
-Make sure the wheel bearings are in good shape (on the trailer)
I've change the rear diff fluid on it at 15k, and 30k miles. It currently has 35.8k miles on it, with the last oil change at 34k miles. I wasn't planning on changing hte tranny fluid until 60k miles, but can definitely do it at 45k miles if we make more towing trips this year...
Thanks in advance...
