NorCal 2004 4Runner
Looking good so far what'r the next mods?
Thanks, next mod definetly will be to pull the running boards and finish the stereo system.
My plan for the system is to install Infinity separates up front and coax's in the rear. Also a Sound-stream 5ch amp and 10" sub in a custom box molded in the right rear panel.
Unfortunately I won't be able to start the system until after the end of May because I'm preparing my RC rock crawlers for a competition in Montana.
It's been a few months since I worked on the Runner but a couple weeks back I got the itch to start modifying again. I started by getting a new exhaust system including a 50 Series Flow Master and a nice side output chrome tip, nice low rumble without being too obnoxious.
DSC04984.jpg~original
Then I bought some stereo gear in a late night buying spree.
From the left to the right, Monster 16AWG twisted quad for the the front components, twisted pair for the rear coax. 4AWG power and ground wire. Monster four pair RCA's and one two pair for the sub. Kicker 100 A fuse holder and battery terminals:
DSC04996.jpg~original
Kicker 10ZX700.5 amp, sub bass controller, 1 Farad capacitor and some Dynamat.
DSC05000.jpg~original
CDT Audio CL-62 components, CDT 6.5 coax, Kicker Comp CVR 10" dual VC 4 Ohm woofer that I got used from a buddy and I bought a new grill for.
DSC04998.jpg~original
My goal for this system is high sound quality on a moderate budget and minimal impact on stock storage and functionality. I just ordered a temporary sub enclosure but will eventually make a fiberglass enclosure for the passenger rear panel.
On to the install...
I started the install by gutting the inside of the truck, it didn't take too long at all but this ain't my first rodeo either.
DSC04985.jpg~original
I used the factory drivers to trace out the baffles on 1/2" MDF. I used 1/8" MDF for the tweeter mounting plate.
DSC05002.jpg~original
Then I busted out the heat gun and roller to help lay down some Dynamat on the front door. Also ran the twisted quad speaker wire into the doors using the factory boot
DSC05008.jpg~original
Same story but rear door
DSC05009.jpg~original
I took the front cover off the sub bass controller and mounted the in the left hand switch bay of the center console using supplied hardware.
DSC04991.jpg~original
It always bugged me that the DAC switch is located in the center console so I decided to move it to the left side of the steering wheel. Just cut the plug and made a nice long harness. Also rewired the head unit harness so I could add a switch to open the illumination circuit in case I want to run day time running lights and not dim the screen.
DSC04992.jpg~original
I primed and painted the speaker baffles and then used foam tape to seal the back of the speaker and the back of the baffle, all bolted up they fit tight.
DSC05011.jpg~original
DSC05013.jpg~original
I ran the 4 AWG power wire through the the stock firewall grommet and to the kicker fuse holder. I had to fab a mounting bracket using 1-1/2" aluminum angle.
DSC05024.jpg~original
I ordered up a Optima 34R red top battery and installed it with 1 x 2" aluminum tubing under the hold down bracket. I ran a 4AWG ground wire from the chassis to Kicker battery terminals, they seem nice and fit well just hope the plastic covers hold up.
DSC05023.jpg~original
I installed the cross-overs for the components under the front seats and ran the speaker wire and power wire down the driver side.
DSC05019.jpg~original
I ran the RCA's, remote, and sub bass controller down the passenger side
DSC05021.jpg~original
And then quickly wired the amp to test the system.
DSC05014.jpg~original
Thanks drifter
Went ahead and mounted the cap to the seat back and then the amp with some 1/2" spacers so I could route the wires under the amp
DSC05026.jpg~original
Still need to strain relief the wires with some padded clamps but for now it works
DSC05027.jpg~original
To finish up I bought an off the shelf woofer enclosure because I probably won't get to build the fiberglass enclosure for another couple weeks.
DSC05028.jpg~original
Still need to tune it but all in all the system sounds great! Plenty of power, clean highs, rich mids, and tight bass.
So I haven't had the time to start the fiberglass enclose but I was able to install some Dynamat in the rear.
Just a couple small pieces on the driver side to dampen out the stray bass and road noise:
DSC05029.jpg~original
On the passenger side I used a lot more Dynmat since the enclosure will fill this cavity:
DSC05034.jpg~original
Last week end some more performance mods arrived, fist an aFe silver bullet throttle body spacer:
DSC05030.jpg~original
And also a aFe stage two cold air intake:
DSC05031.jpg~original
I hear the throttle body spacer doesn't really help performance at all, I think it does cut down on intake whistle though. The CAI sounds pretty cool and it really opened up the upper RPM range, seems like it hurt the off-the-line performance a little.
To fix this I decided to get a Underdog Racing Development MAF Sensor calibration unit. Since I live in Cali I wired the box using bullet connectors so I can easily disconnect it for smog:
DSC05036.jpg~original
Then a found a nice little spot for it in the passenger kick panel:
DSC05038.jpg~original
This truck now has awesome throttle response and the upper end is screaming all the way to 5k! This unit really rounded out the exhaust and intake mods, best performance upgrade so far!
100k mile update!
Been awhile since I did any work on this old rig so last week after the odo turned 100,000 miles I decided it deserved an upgrade. I've been needing new tires and been looking at the FJ's TRD/BFG wheel and tire package since they run the 265-75 R16 AT's, which is a nice small increase in diameter from stock. Not sure others noticed but after the earthquake in Japan these wheels all but disappeared from the market so last night when I just happened to check Craig's List I decided to jump on a way too good to pass up local deal. Only 3k miles on these bad boys, tires even still have the little nub's on them:
DSC05366.jpg~original
The wheels didn't have the TPMS but I think I can always swap the stems over from old wheels.
DSC05370.jpg~original
Like the size of these tires on the 4Rnr especially with my small lift but I may still need some wheel spacers to get the look right
DSC05372.jpg~original
Just after I took this photo I deleted the running boards, looks sick!
DSC05373.jpg~original
Laredotx
