Notice difference after low pressure pump recall
Andong
My LTD got recall yesterday and I have noticed that my LTD acceleration response decreased for smoother ride which I don't like at all.
and harder to maintain eco light on low speed.
is it only me or you guys also noticed any differences after recall done?
The ride got smoother but the acceleration response decreased from the fuel pump being changed out? Is that what you are saying?
Reset your eco meter.
My headlight auto-off setting changed afterwards, I presume that was due to extended time with the battery disconnected.
ECO mode cannot be turned off, or adjusted, or reset. At most, you can turn off the ECO display on the cluster. You'll need an aftermarket throttle controller if you hope to remove the affects of ECO mode. Mine cost $50 on eBay, but I've seen a few much more expensive items that do the same thing mentioned here at T4R.
Carista allows eco meter setting customization, and the display to be turned off altogether.
Carista is aftermarket. There are lots of aftermarket products that remove the ECO mode accelerator report rate. None of these things were previously mentioned as available to them by the OP.
