Now considering '18 Limited 4WD but...
rzgkane
I think I've decided the TRD Pro has too much off-road equipment I'd never use and the asking prices right now are over sticker. But, I like the look of it better than the Limited. Can I add some TRD 17" wheels and tires to a Limited in order to toughen it's stance without problems in the fitment department?
I saw a new Limited tonight in a parking lot and I liked it, but the front end looked lower than the rear and I wasn't thrilled with its posture. Are some of you Limited owners leveling your trucks out by pumping the front suspension up and inch or two? If so, what's involved there?
No rub and they fit perfectly.
The TRDP has a unique suspension and is slightly lifted. ALL other 4Rs have a slight rake.
It doesn't sound like you've driven the LE. You really should be test driving the various models.
I selected the SR5P because I needed no trail features nor some of the upscale LE features.
The LE has lower front and rear valances, which affect both the look and clearances. The TRP Pro has a different suspension setup so it sits higher. I'm not sure about off road features, but I think they're all electronic. The LE has ATRAC and DAC, so it's not bereft of the electronic features. The main differences, as I understand them, are suspension (LE has XREAS), AWD (LE has a center differential), looks (which are pretty obvious), and creature comforts available on the LE. Good luck and happy hunting.
Why not save yourself some money and just go w/ a SR5 or TRDOR and put the TRD wheels on one of those? Looks, aside from the grille and blacked out emblems area almost identical to the TRDP.
I had the same wants. Meaner stance but limited features. I went with a 17 limited they still had on the lot. Picking it up tonight :-)
I forgot to mention that I NEED a third row seat. That appears to only be an option on the LE and SR5's. I want all the creature comforts of the LE but with some beefier tires and wheels and a level posture. From reading the posts here it sounds like I can accomplish that using Toyota parts and maybe a slight lift in front. Thanks for taking the time to respond.
Dig that look. Is the Canadian LE essentially the same as the US version these days?
I've seen some from BC in the Bay Area and they look a bit different but I can't figure out why.
TRD Pro vs Limited
The only thing I like about the Limited is the leather seats and the stereo upgrade. The valance all around the vehicle is lower by a couple of inches which reduces ground clearance. If you want to add rock sliders to protect the door panels and rocker panels you have to cut off that valance on the sides. If you want to lift it the best option is a spacer on top of the front coils over shocks and over the rear springs. If you want to lift it with better shocks for off road you'll need to start by removing that expensive Xreas suspension. If you ever go off road in the desert or mountains around So Cal, you'll want more clearance and rock sliders.
All the 4Runners have the same low front end and sloped frame, or rake. It's done so you can fill the back with cargo and still have a level vehicle. The T4R has one of the largest cargo areas of all SUVs.
The TRD off-road is off road capable as sold and can be easily upgraded with rock sliders and suspension lift. Yes, the TRD Pro is sold for a high price. When I was looking in 2015 they all had accessories I didn't want piled on to make it more expensive. I bought the Trail Edition, ordering one without any accessories, sun roof, sliding cargo deck, etc.
If you buy the Limited consider buying my 2015 Trail Edition rims and tires with 25k miles. The TE rims are 17x7.5", which is wider than the TRD 7" wheels, so it's able to handle a wider tire, like the 275/70R17. Those are also a bit taller than stock.
If you never plan to drive the vehicle off road then by all means, get the Limited and enjoy the leather seats, chrome trim and enhanced stereo. Oh yea, you need the 3rd row seat. That limits the options. If the 3rd row is for adults you should try sitting in that 3rd row before you buy one. The foot room is small.
I just bought 17x8.5 rims and mounted LT285/70R17 on my trail edition. To fit those tires in the wheel wells, I'm also upgrading the shocks with a 2" suspension lift using ICON shocks.
I'm guessing the USA versions don't have the bulky running boards like the CAD one? And it looks lower because of the front end bumper design.
Do you have a photo of it when it's all cleaned up? Im thinking of getting some TRD Pro wheels for my winter rims.
They should be exactly the same,the only difference is that Canadian models all come with 4wd and our TRD Pro has moon roofs
Not really. I have a few friends live in Kentucky,Wyoming and Maryland who all have Ltd and theirs have the same running boards as the Canadians. I think that’s more of an option at the dealership.
Cannot say for sure about Canadian models but my 2017 did not come with running boards. As of a couple of weeks ago it has a set of Off Road 17" wheels with KO2's and also a set of Off Road rocker panels. Looks a bit different with the lower front bumper of the LE but I suspect there will be a Pelfrey built on there before too long.
Ambrose67
