OBD Port no power and Warning Lights
RaginTxn84
Howdy all - so I had a question (which I found some guidance here) that has now led to another question.
So my BIL's wife has a 2011 SR5 4x4 (blizzard white of course), and when they replaced the suspension, they disconnected the battery - did the install - hooked the battery up - popped up ABS (solid), 4WD (flashing), and VSC (solid). So most of what I found said to get the truck scanned. She went to do that, but both auto zone and jiffy lube said the OBD port is dead.
Is there a second port that can be scanned? I thought maybe a fuse, but then I read that there wasn't a fuse?
Any guidance would be appreciated - thanks!!
Sent from my Pixel 2 using Tapatalk
It has a 7.5 amp fuse in the driver side kick plate fuse panel, last one (Or first depending on how you see it) in the middle column.
2001ATL
