dwulffusa
Just been on a 600mile return trip and have the following observations:
Travelling at 10-15 over (mostly 80ish) got 20-21mpg true (22indicated). That I think is damn good considering the weight, all terrain tires and at that speed incl some headwind.
Stability - Its really getting pretty bad, slightest cross wind makes it dance all over and you really have to concentrate to keep it in in the lane, specially an issue when traffic gets thick. Also nose dives alot on braking.
Is it even possible to put a higher grade of shock on to improve on road stability, or is the Xreas set up all connected and complex, so unless that is removed this is a no go?
Transmission - when climbing quickly and hard on the gas when in 5th o/d the transmission hesitates then thumps violently into 4th. Is this normal because of the aggressive throttle input to get going?
Brakes - Shudder is back during light braking after rotating discs and replacing pads at about 44,000. I know I brake pretty hard around town, but considering my mileage is mostly interstate, I expect better life than this.
Its all nitpicking, and if all that were perfect this is all the car you'd ever need for all purposes. Hasnt missed beat ever, and still lookes great.
