Occasional Vibration when stopped @ light or stopsign ? `
combatmedic
Banned
Hey fellas. Truck is driving great, however when stopped @ a stopsign or light from time to time the truck vibrates pretty heavy, if I put her in Neutral it stops. Any idea? The tranny fluid and stuff is good. And this only happens occasionally. Anyone else w/ a similar issue? As soon as I give her gas, and start to accelerate its fine.... 00 V6 2wd. sr5
It sounds like the symptoms my truck had before my injector started going out, stopped at lights and whatnot it would vibrate a little bit. but it could be nothing though, has a check engine light come on? if not you should be okay i wouldnt worry about it.
If you're getting a CEL, get the code read. Mine was doing the same thing, got a code for Cylinder 1 Misfire. After changing plugs, wires, and a coil pack, we now think it's the fuel injector on Cylinder 1. We tested the injector by simply unplugging the electrical connector to it. When the truck made not change to it's idle, we tried the injector next to it, and the truck stalled out.
If there is no change in the idle, chances are the one you unplugged is either finished or on it's way out.
Hope this helps!
